Anyone add an auto-dimming mirror?
herdbull
I would like to replace the oem flip style mirror that came on my '22 Tradesman. Everything I'm finding for aftermarket options is the digital style mirror. Anyone have a link or experience with just an auto dimming rear view mirror?
@Jimmy07
I believe it can be done aswell as auto high beams if you are interested jimmy knows more on the subject
My gut tells me this should fit (68325128AA) but I would need the corresponding plug and have to run wires. Which I'm ok with. The local parts counter guys here aren't really much help. I would assume the mounts on the windshield would be the same. But I'm not really sure.
Mirror with auto high beam and auto dim- 68312206AA
or Mirror with auto dim only- 68453788AA
Mirror header harness, without cab lights- 68475612AA
or Mirror header harness with cab lights- 68475611AA
Lower cover- edit- searching for part number
Upper cover- edit- searching for part number
2nd upper cover- edit- searching for part number
And AlfaOBD to turn the features on.
Awesome, thanks for the part numbers. Could a guy just wire this to a switched power source and not spend the $60 on the wiring harness and needing AlfaOBD? I don't have AlfaOBD and the cost for that and harness is more than the mirror.
Nope, it needs the linbus circuit to function, and AlfaOBD needs to change the BCM settings to make it work.
What are the settings that need changed?
Auto Dim Mirror:
VehConfig 3: Interior Electrochromic Mirror Present- YES
LIN & Misc- CRVMM Present- YES
Auto High Beam- above settings plus:
VehConfig 1: Auto Highbeam- YES
2014 CBC Config I/O & Feat.: Auto High Beam Module Location- CRVMM
CustSetMenu 1: Auto High Beam CSM Present- YES
Auto Dim Mirror:
Does the auto highbeam have a special windshield required for the sensor? Or will the standard windshield work?
**I Edited my post above**
I don’t think the covers I posted have the hole for the auto high beam camera, so I’m trying to double check that. I’ll re-post the correct covers for both types of mirrors when I figure that out.
I just installed the mirror with both auto high beam and auto dimming that you listed here, I already had the auto dimming mirror without auto high beam. My existing wiring and mirror covers were ok and the cover already had the cutout for the high beam camera. I am real happy with this new mirror, the dimming area is bigger and seams to work much better than my original mirror. Its isn't dark enough yet to see if high beam comes on, will be testing later and let you know.
Got the mirror on Ebay for $150
Auto high beam works, but it seems not to be sensitive enough. Twice after a vehicle coming at me the headlights dimmed but then a couple of seconds later went high making the other vehicle flash their brights at me. Whish there was a way to adjust sensitivity.
Update, I took the sensor for auto high beam apart and painted the interior white, thinking this might increase the light sensitivity, will know tonight when it's dark enough to test.
I ordered the mirror cover ( 6PA22TX7AB ) for my install and yes it comes with the cut out for the auto high beam sensor.
