Wheelz
I'm trying to get feedback if any of the Dually users here have coverted over to 19.5 rims with commercial tires? I'm going to be doing a lot of equipment hauling and wanted to use commercial tires for longevity.
All the 4500/5500s come with themI'm trying to get feedback if any of the Dually users here have coverted over to 19.5 rims with commercial tires? I'm going to be doing a lot of equipment hauling and wanted to use commercial tires for longevity.
I have a 4500 Cab and Chassis dually with 19.5 with Continental HSR for steering tire and a HDR + for rear traction tire. When not hauling I keep tire pressure front at 60 psi and rear at 65 psi in which doesn't require a kidney belt while driving without any weight and hold up nicely.I'm trying to get feedback if any of the Dually users here have coverted over to 19.5 rims with commercial tires? I'm going to be doing a lot of equipment hauling and wanted to use commercial tires for longevity.
Ah..this is good to know..I couldn't for the life of me find commercial grade tires in 17" . All I've seen are 19.5 and up. Thanks. I was hesitant to drop 6k on wheels and tires for the 19.5 conversion.You can get commercial 17's. I don't know if they're actually classified as commercial or not but I'm positive the Bridgestone R500HD is constructed with commercial technology. I've hauled heavy with them for lots of miles and never had an issue. They're rock solid and get tons of miles. They're the only tire I've ever found that wears very well on the front of a GM 3500 with IFS.
There are trade-offs versus A/T's and the like that most of run on our trucks but if you're prepared to go to 19.5's you're already going to give up those trade-offs and then some.
Just another potential option.
I have changed plenty of 19.5s with bars and never scratched them its all in the technique and most shops will do it without scratching themChanging to 19.5's would be the last thing I'd do on a 3500 unless there was no other option. No automotive place around me will change 19.5's. Commercial truck companies are the only ones that will do it. To get it done and not have your wheels destroyed is about $475-500 mount and balance. Almost all commercial truck place don't have machines they lay it on the ground and pry bar city. Same thing if you needed roadside repair, it's going to limit your choices and be really expensive for a decent job.
