Another Newbie
Houston HB
Houston
Hey just wanted to check-in and say hello. First time owning a Ram 2500, but had the eco diesel. Went ahead and deleted the eco and have about 100xxx miles now on it for a work truck. My new 2020 white with blackout opt 2500 is currently waiting on the 6in lift and 22x12 -44 with 37 to come in. Ill post photos once everything is put on.
Looking forwards into reading alot around here.
btw can someone point me in the direction how to recalibrate my new wheels using the alphaobd for speed and tpms, thanks guys
Welcome and Congrats!!
Congrats and welcome to HDRams!
Coming from the 1500, do you have a Koadtech bypass cable or the infotainment bypass module? The module doesn't play well in the HD's due to the harness location (behind EVIC).
I was unable to get the quick link speedo recal in AlphaOBD to work so I went the long way around.
Change the following:
Then do the ABS reset procedures. If you cycle the key before you reset, you will set codes and have to clear them.
Then do the ABS reset procedures. If you cycles the key before you recall, you will set codes and have to clear them.
no on my 2015 i did not need to have a bypass cable. where do i buy it from
also what is the long way around i am pretty new to the AOBD so i need step by step sorry for being a toddler on this subject just dont want to mess anything up
Welcome...Looking forward to pictures!!
I got photos on the way my lift in coming in and the wheels and tires are here. Currently I have installed amp sidesteps by myself and did the retrax cover for the bed, did 3% tint. Currently going back and forth on deleting but i still have 36k warranty and dont want to mess that up
@Houston HB
P.S. You may want to consider getting the Windows version of AlphaOBD if you haven't already and that's viable for you.
There are some issues with the Android version and doing 2020 settings on a 2019 (have to force BCM year). May not affect you, but if you wanted to help a buddy...
There's also been a few 2020 owners, myself included, that have had settings changes not work as expected and the Android version is suspect.
