I think the two motor Amp Xtreme steps drop the same distance as the single motor standard Powersteps. I can take a measurement of my standard powersteps tomorrow.
I have the AMP Research Extreme on my 2023 ram 3500 Longhorn... here is a pictureDoesn't seem like it should be such a difficult spec to find but I can't so I thought I'd ask here.
If anyone owns a set of these things, could you tell me how many inches from the bottom of the door to the top surface of the step?
Thanks
Aren't you supposed to relocate the air tank when installing these? Didn't know you could install them with the tank in the OEM spot.Gotta take mine in to have them replace the right side Amp Running Board, reason being is it hits the air tank for rear suspension air bags. It has rubbed a dime size area of the black anodizing of the running board. Believe the fix will be once r/s running boards is removed, the need to make the slot for the mounting bolt a bit longer in order to raise the tank up 3/8" to 1/2" so the new running board doest hit the air tank when it tucks away!!! Other than that, I love the Amp retractable running boards.
The problems isn't how far they drop, it's when they retract when it hits the air tank mounted just above it, so it appears that the tank should have to be raised if possible out the mounts for the AMP Running boards lowered.I think the two motor Amp Xtreme steps drop the same distance as the single motor standard Powersteps. I can take a measurement of my standard powersteps tomorrow.
That appears to be 4 3/4" down from the bottom of the cab.I have the AMP Research Extreme on my 2023 ram 3500 Longhorn... here is a pictureView attachment 61731
Appears to be 4 3/4" down from bottom of the cab. Brewbud thought he said his drop was 9".I have the AMP Research Extreme on my 2023 ram 3500 Longhorn... here is a pictureView attachment 61731
The dealer did the install or sent it out to get done. I'm not sure who but I would think whoever did the install before I took possession should've known!!! But thanks I will suggest that when I'm able to take it in, it's my only vehicle at the present time.Aren't you supposed to relocate the air tank when installing these? Didn't know you could install them with the tank in the OEM spot.
Thanks Late to the party, appears to be between 6"-6 1/4" from bottom of cab. The other picture posted was 4 3/4". Maybe they can be moved down lower so they don't hit the air tank for my rear air bags or the tank is supposed to be moved from OEM located spot? Will update a after its gone back to the dealer.
CdnHO, thanks for the comment, but mine are AMP not OEM running boards and are retractable on my 2023 Ram 6.7 HO CC, Dually with 8' bed, 4x4.My factory steps drop 9 inches below the bottom edge of the door. I suspect the OEM would be similar to the AMPs. Certainly they are lower when deployed than the fixed running boards.
The Amps also drop 9". This puts the door sill at 14".
ThanksI have the AMP Research Extreme on my 2023 ram 3500 Longhorn... here is a pictureView attachment 61731
I also have issues with the two motor version hitting the air tank when retracted! contacted amp research and they sent out the incorrect tank relocation kit. I ended up using a small dremel grinder to created slots in the tank mounting brackets instead of holes and was able to get just enough clearance to stop the clunking noise from the boards hitting the tank. Hope this helps a little... I understand your frustration with various info out there.Thanks
