Newtocummins2021
So, I have a 2021 Ram 3500 crew cab long bed. I ordered the truck and was trying to keep weight down so I only wanted the Laramie 1 package. For some reason Ram won’t let you add the factory power steps with the Laramie 1 package. I was fine with that as I have installed AMPs on my previous 2 trucks and my wife’s suburban.
found a deal on the AMPs and ordered them. Went to install them and they were by far the most difficult install of the 4 sets I’ve done. Finally got them installed and inserted the fuse as the last step and they wouldn’t retract. After days of troubleshooting I finally determined they sent me the wrong controller. They ordered it for me and failed to tell me it would be 2-3 months till it arrived.
it finally arrived and I installed it to find out the steps wouldn’t retract all the way and hit the pinch weld. I was fine with it but, it finally retracted past the pinch weld and got stuck. Watched the AMP video on how to adjust the steps where you loosen the lower bolts and bounce on the step to “seat” it all the way. Finished adjusting it as they said and it still would hit the pinch weld and get stuck behind it. Used a grinder to grind down the pinch weld where it was hitting and got it working until I installed the end caps. Don’t know how much more I can grind.
so I’m here seeking help for some tricks on how to get these to function properly befor I take them off and toss them in the trash. Thanks
