Bad day. A varmit chewed through wires inside the gate above the lic plate. Now I can't lower the gate with the key fob, handle on gate or inside the cockpit. What makes it particularly an issue is I have a triple fold hard-top that can only be flipped from inside so I am locked out of the bed. I can see two frayed wires protruding from the gate bottom above the lic plate. White and black however the black is now only insulation, the conductors are not there. Very limited access feeling under the gate so no luck in pulling down the wiring harness. So to keep from demolishing the triple fold lid is there a way to directly power the gate solenoid actuators? can a bit be flipped from the ObD II scanner connector in the drivers foot well? Any suggestions for bypassing and/or hot wiring would be greatly appreciated. D%$# critters!
