AlphaOBD and aftermarket HID Fog Lights
david.dean65
My 2024 Ram 2500 came with the base model fog lights (non-LED). I installed a XenonPro HID Fog kit that came with the ballasts and anti-flicker modules. I did not need to make any programming changes to the BCM via AlphaOBD, and everything works great. Except that I'm now having to replace another ballast (within a year) that is giving me indicators that it's about to go bad. XenonPro has a great warranty program and they sent replacement parts immediately when the first one went out.
My question is this... if I use AlphaOBD to program the fog lights to HIDs, can I remove the aftermarket anti-flicker modules?
Much appreciate the responses.
UPDATE... I changed the aftermarket HID fog lights to LED. I did this because I was going through too many HID components prematurely.
I installed the LED fogs without the anti-flicker and they work just fine, plus there's less components that needed to be installed. Additionally, I did not make any changes with ALFAOBD and everything works great. Seriously thinking about changing the headlights to XenonPro LEDs.
