Alpha OBD Question
Tom716
Can someone explain to me, kinda step by step, how to change my tire size using Alpha OBD? I just installed some 37's and I know my speedo is going to be way off. Thanks !
It's a straight-forward process, but I'd hate to try and write it out from memory and miss a step, so I'd recommend surfing these two threads , where it is covered.
There is also a good document on a Google drive, but since I'm on my work laptop I'm blocked from it, so don't have it bookmarked here. It is titled something like "AlfaOBD Known Working Settings". You may be able to find it through a browser search.
Sorry for high jacking this thread ... but I am curious as to exactly how much AlfaOBD costs I plan on installing the EZ Lynk tuner and seeing if I can work the two in conjunction with each other
It looks like the current licensing costs are $49 USD for the Android version and $56.70 USD for the Windows version. And the website doesn't mention specifics, but it does state that if you buy both there is a discount.
Not sure what you mean by in conjunction? I have both and run Ezlynk for my daily monitor and plug in the Alfa adapter (unplugging ezlynk) if I need to make a change to the vehicle which isn't very often. Don't think you can get away with a OBD splitter and running both at the same time?
Good to know
Two active OBD devices won't generally get along at the same time.
