We have a new to us 2021 Powerwagon with Carli Pin Top Suspension and Carli fabricated radius arms with a truck top camper. On our first off road camping trip we did some moderate rock crawling but nothing extreme, all at low speed and we never hit anything. Once we were back on the pavement it pulled left, which it didn't do on the way there. We took it in for an alignment at a shop that is familiar with Carli suspensions and he couldn't get it into alignment. I didn't take a photo of the results (and he didn't finish the alignment because he felt bad because he said the fix is going to be expensive) but I know one side was at 8 degrees and we think the other was around 3 or 4. He said the likely cause is broken plug welds and a spun axle tube. We have been trying to figure it out since then. There are 5 plug welds on axle housing on the passenger side of the differential housing. One of them (the one closest to the diff housing on the front side of the housing and close to the top) rocks (the one in the top right of the attached photo). The other four plug welds on that side axle housing seem solid and only one may have some oil leaking out but it is hard to tell if it is from us touching it or if it is oil leaking out. We don't see any evidence of problems with the plug welds on the driver side of the diff housing. We aren't convinced it is a spun axle tube. It is obviously costly to have the front axle removed and inspected. Is there anything else we should look at or do before taking it to a differential shop? Should we take it to a different alignment shop? We are in Northern California Bay Area. Thanks for any insight!! We want to get back out on the road and enjoy our truck!
