K Kavanaghb New Member Messages 2 Reaction score 0 Points 1 Sep 13, 2023 #1 Obd download truck log to google drive shows nothing in file any help would be appreciated
44Dan44 Well-Known Member Messages 773 Reaction score 1,278 Points 93 Location Maryland Sep 14, 2023 #2 Welcome to the forum @Kavanaghb See this for a lot of info, also post there with your question, more people with knowledge on your issue likely to see and respond to your question. https://hdrams.com/forum/index.php?threads/alfaobd.640/
Brutal_HO The Mad Irishman Staff member Messages 14,297 Reaction score 26,699 Points 113 Location Douglas County, CO Sep 14, 2023 #3 Did you "Read System ID" and "Read System Status" first? You should also connect to the BCM and go to Active Diagnostics, and "Backup Vehicle Configuration to file."
K Kavanaghb New Member Messages 2 Reaction score 0 Points 1 Sep 14, 2023 #4 Brutal_HO said: Did you "Read System ID" and "Read System Status" first? You should also connect to the BCM and go to Active Diagnostics, and "Backup Vehicle Configuration to file." Click to expand... Thank you,I just came across this as a step that needs to be done and did this and it worked . Thank you for responding
