AlfaOBD
wsgooch1952
I am installing Blind Spot Monitoring to my 2022 Ram Laramie 2500. I have the new mirror glass and taillights installed with the associated wire harnesses and bypass supplied by Jimmy07. I purchased the AlfaOBD sofeware for my PC laptop and the OBDLinkEX interface. I am needing help with the steps to activate BSM. Here is a list I came up with by searching my truck log for blind spot:
Active Blind Spot Present: No
Blindspot Mirror Present: No
Blind Spot Alert CSM Present: No
Teen Key Blind Spot CSM Present: No
Blind Spot with Trailer CSM Present: No
Blind Spot Warning CSM Present: No
Active Blind Spot Enable/Disable CSM Present: No
Active Blind Spot Warning Mode CSM Present: No
Active Blind Spot Sensitivity CSM Present: No
Active Blind Spot Strength CSM Present: No
Active Blind Spot Haptic CSM Present: No
Do I simply change all these to Yes? Or are there other steps required. Any guidance will be appreciated. Thanks!
Hey, I’m trying to do the Blindspot monitoring Alpha programming but the alpha that I have on my laptop doesn’t look anything like those selections. Can anybody help me?
Click active diagnostic at the top of the window, then scroll down to the bottom of the list and select "car configuration change" you will find what you need in that list.
Be sure to make a backup copy of the BCM before making any changes
