AlfaOBD Users, I need your help
TejasTJ
I can't get a response from Jimmy07 so I'm reaching out to you guys. I'm trying to troubleshoot a led projector headlight swap with Jimmy07's harness. I've got a "turn signal bulb out" but test good via the lamp test.
Please share a halogen headlight BCM config and a Limited/Longhorn BCM config.
These are the changes I've made
**- CBC Features: LED Front Turn Lamps Present- YES
**- CBC Features: LED Low Beam Lamps Present- YES
**- CBC Features: LED High Beam Lamps Present- YES
**- CBC Features: LED Front Park/Marker Lamps Present- YES
**- CBC Config I/O: Right Dedicated DRL Lamp/Right Signature LED Present...- NO
**- CBC Config I/O: Left Dedicated DRL Lamps/Left Front Turn Signal #2...- NO
**- CBC Config I/O Usage: Front Park/Signature Lamp Left- Pin A 7- YES
**- 2014 CBC Config I/O & Feat: Front Park/Signature Lamp Right - Pin A5- YES
**- 2014 CBC Config I/O & Feat: Headlamp Module LIN Diagnostics Line Enabled- YES
**- CBC Extern.Light Calibr: Signature Light Present- YES.
**- CBC Extern.Light Calibr: Redundant Front Turn Signal- NO
**- CBC Extern.Light Calibr: Signature Dropout Enabled- YES
*- CustSetMenu 1: Adaptive Front Light system CSM Present- YES
*- P/T Chassis Net: AFLS Discharge Lamps- Enabled
