AlfaOBD Question - Tire Pressure Config
Question, anyone know what the top four settings are for under “car configuration” in alfaobd in the attached pic?
Someone, cough cough, may be an idiot and adjusted those instead of the correct “update pressure thresholds” when adjusting for lower tire pressures. Was a late night, few projects took a lot longer than anticipated and I was rushing. Also didn’t do a backup as I should have before adjusting b/c I thought it would be quick and easy.
Appreciate any help in advance
The max load rear and max load front are the actual settings that you are dealing with when changing the tire pressure thresholds (the “update pressure thresholds” is just a shortcut to these two settings).
The two light load settings will be “0.000”, since ram trucks don’t have a light load inflation button.
