Screech
I am trying to get 3 levels for the heated steering wheel working on my 2500. I was able to enable other features with AlfaOBD just fine but the heated steering wheel settings are still just showing on or off. Ive tried setting it to 2 and 3 levels and its the same thing. I have noticed that the steering wheel does not get as hot as it used to despite the ui showing on or off. I unhooked the 12v battery for a bit and its still not showing up. Is there some other settings that need to changed besides the ones in the AlfaOBD thread?
- ECUConfig 3: heated steering wheel present- YES
- Memory: heated steering wheel present- YES
- Seats A: Heated Wheel Levels- leave as “Not Defined” for on/off, or choose 2 or 3 level
***NOTE*** Make a backup file before you change the wheel levels. Otherwise you can not go back to the on/off “not defined” setting because it isn’t in the list.
- Seats B: wheel material type expansion- TYPE 3
