wpgram
I'm adding airbags and I cant justify the cost of the wireless setup.
Where is everybody mounting the gauge and switch?
You bought a 100k truck and put 35s on it but you don,t want to spend 500 bucks for a wireless controller and compressor ? ok? the non wireless I had meant drilling a hole in the dash and running air lines to the back , was a pain and lots of leaks thats where I mounted mine, on a side note you should keep 5psi in your bags all the time " manufacturer recommendation " and the wireless controllers do that automatic which is what I use in my other 2 trucks and will in the 2021 , its so much easier than babysitting the dual gauge in the cabI'm adding airbags and I cant justify the cost of the wireless setup.
That would be USA according to their website Duty, shipping,brokerage,taxes too expensive sometimes to ship to Canada.
Ive got three trucks with Air Lift single path wireless and have had no problems ( knock on wood ) I feel a little better pricing, quality and availability. I,ve had the hard line dual path twice into the cab they were a twin gauge with an air release button and a control switch , long air line back to the bags and they leaked alot so I went wireless, They leak sometimes also but most bags require you keep 5psi in them , and the wireless does that automatically, good luck with your own idea, I would like to read about it.I have read alot of reviews on the firestone remote system and it is not very good.
Im going to be building my own remote system. i will post some info once its done
