sadram
Hi all, I have a 2018 Ram rebel I recently replaced the 5th air pump for the suspension, vacuum the system with HVAC gauges and vacuum pump refill the system with nitrogen to 175 PSI took it out of plant mode configure the right height values the system works it goes up and down through all its settings but when I start up the vehicle the air pump consistently runs to the point where it says air suspension system requires immediate service would anybody know if this is due to air suspension module failure or could I just reflash the module any help would be gladly appreciated
