I’d setup for Alt. Alt will essentially level the truck which is arguably ideal when towing. Either is fine tho I believe. Without Alt, it looks more “normal” not towing with a slightly high rear as would other non air trucks.Ive got a 2500 with the rear air suspension and Im picking up a travel trailer next week. When I setup the weight distribution hitch should I do it at the normal ride height or at alt trailer height?
In case you don’t know, put your air suspension in tire change mode while you are putting the bars on, else the air suspension will be fighting you.
I think they are a little different. This shows how:Maybe the 2500 is different, but I've never had the 3500 fight me when installing or setting up WDH. I find it actually makes it easier to hutch up, and unhitch, with the suspension active.
Thanks for all the replies. I'm planing putting the truck in alt height then hooking up the trailer and letting it re-level. Then putting the bars on and adjusting the tension. I'm picking up the trailer on Friday so Ill let everyone know how it goes using that process.
Agreed. I've owned 2 2500's with factory air. I never mess with the air settings when hooking or unhooking a trailer. I tow at normal ride height, which is how I setup my WDH and trailer level height.You don’t have to disable anything to hookup.
![IMG_20250301_163949[1].jpeg IMG_20250301_163949[1].jpeg](https://hdrams.com/forum/data/attachments/83/83023-6fee2228a548ed31d45f67bed164e792.jpg?hash=GLitTq7d7a)
