looking at buying some new rims. What kind of offset can be obtained on stock suspension. Will negative 12 or negative 18 cause rubbing on stock suspension?
Fit is a function of multiple factors, not just the offset. Tire height, tire width, offset, and rim size all affect the fit. For example, a negative 18 offset might be right for a 35" tire, but not for a 37" tire.
I recommend emailing Sales@ CJC Off Road <[email protected]> with the tires and rims you want to use. They will tell you pretty quickly if they will fit without trimming or other modifications.
I’m on a 9.5 in wide rim with a +12 offset and I have about an inch and a half of tire sticking out and they are stock tires, they will stick out even more with the 35s I plan on throwing on there. Unless you are going for the brodozer look then I wouldn’t get crazy negative offset.
