The screws weren't that difficult, particularly the ones in the middle once you have the air dam off. It's a bit of a two-step process. Just loosen the 8mm nut, you don't need to take it completely off, then pull the stud bolt out of the grille.
I was able to get those in just a few minutes. There is one that likes to hide behind the CTD intercooler shroud, but it's just a matter of pushing it to one side or the other. The ones in the corners of the tow hooks are a bit trickier but with a little contortion you can get a box wrench in there and it only takes a couple of partial turns to get them loose enough to pop out the studs. Just be careful not to drop them.
Where this became futile was when I tried to remove the grille and it was still in there solid. I found that on either site of the stud bolts are two tabs that have to be pried from the bumper. The ones in the middle again are manageable, but when I got to the ones in the corners, it proved to be impossible to get those tabs to free up. At this point I decided that the work I am doing is accessible from the back of the grille and gave up. I think the only way to get that grille insert out is to remove the entire bumper and IIRC, you have to take the upper grille out to get to a couple of bolts.
Hope this helps, Erik
