The specs on the tires are when they are inflated, but not under load. Found that out the hard way.
The reason measuring the tire height doesn't come out right is because the load is actually only on the lower half of the tire. That's why Jimmy and I said to measure the bottom half, then double it. That's gets you about as close as you can, without actually doing the rolling measurement I mentioned. I didn't invent it, just passing on knowledge I've learned from others.
The reason to use the actual rolling measurement is because that is exactly what the computer is using to determine speed. How much ground did the vehicle cover for one revolution of the tire.
And if you want to get real nitpicky, it will change depending on the pressure in the tire. Higher pressure will make the ground covered more. Lower pressure will be less.
Not trying to be a A hole. Just want to make sure correct info is being put out.
I watched a youtube video last night about installing a split AC system. Guy seemed to know what he was talking about. he even showed that his system needed 12 gage wire and a 15 amp 2 pole breaker for 220 power as per the manufacture. All is good right? At least to that point.
Then the guy shows he has some 10 gage 3 wire that he's going to use instead of going out and purchasing the correct size wire. No big deal as he had it on hand.
And the 10 gage wire is rated for 30 amps. So he goes and puts in a 30 amp breaker.
Well the manufacture spec said 30 amp breaker for a 10 gage wire, so whats the problem?
But that was for a system more than twice the size of his. If that system has a issue and draws more than 15 amps, he's going to burn stuff up, possibly even his building.
