Adding lower instrument panel drawer
dmhines
Easy swap. Replaced lower storage cubby with drawer. This drawer came out of a late model 1500 - they are identical to HD drawers. I trimmed the original close out bezel until I get the correct one The correct bezel has an opening for the unlatch button.
How did you remove the original trim piece that was there? Any screws or do you just pull trim piece until it comes loose from clips? Thanks for the picture I’m going to try and find a used one on eBay and add it to my 2500. Do you remember the part number I have seen three different ones on eBay. I don’t have the 400 watt plug on right side but I think it will fit. One with just USB port like I have now is $345.
I ordered part 6RP72TX7AB for the black bezel. For the drawer I just found one on eBay that matched my configuration which was USB and power outlet. The bezels just pull out using clips. Bolts hold in the drawer. It will make sense when you see drawer assembly and start removing the cubby.
