Adding Line Out Converter - 2023 Tradesman
goindownhole
I've added a line out converter with amp/sub to a 2023 Tradesman at work and am running into issues. Had zero issues in the 2022 & 23 GM pickups I swapped from, also running the same setup in a Ford with no issues.
This is a base model truck with 5" screen. No options.
I have the LOC on the driver rear speaker. While setting gains, I can't get close to the output voltage (on multimeter) I should have until I bump up the bass on the equalizer. Once I bump up the bass to max, I get some decent power.
Also, the truck has a couple plugs under the back seat. One on each side that are 6 pin+ and one on passenger that is 4 pin. Any of these for factory sub?
Is there a harness specific to this 5" radio? 99% of the Google results are for the 8.4 and 12.
Thank you in advance.
