Adding LEDs to Bed
22BlackBigHorn
Hello, I have a 2022 Ram 2500 BigHorn, but it does not have the LEDs in the bed. I was thinking of either purchasing these or running some other LEDs under the rails.
My question is, is there a harness or plug I can tap into for the power for it back there for the cargo light?
I taped into the 12v power wire from the 7way harness. I used a ground disconnect switch so the lights automatically shut off when the tailgate is closed. I also wired in a switch so I can still turn them off if I need to leave the tailgate open but don't want the lights on.
That is a great idea. Do you have any pics of where the switch is located? I take it then you used some sort of LEDs in the bed not the cargo lamp?
Ram sells the kit to add the OEM setup
