Adding Blind Spot to 2022 Laramie 2500 Using AlfaOBD
wsgooch1952
I am installing Blind Spot Monitoring to my 2022 Ram Laramie 2500. I have the new mirror glass and taillights installed with the associated wire harnesses and bypass supplied by Jimmy07. I purchased the AlfaOBD sofeware for my PC laptop and the OBDLinkEX interface. I am needing help with the steps to activate BSM. Here is a list I came up with by searching my truck log for blind spot:
Active Blind Spot Present: No
Blindspot Mirror Present: No
Blind Spot Alert CSM Present: No
Teen Key Blind Spot CSM Present: No
Blind Spot with Trailer CSM Present: No
Blind Spot Warning CSM Present: No
Active Blind Spot Enable/Disable CSM Present: No
Active Blind Spot Warning Mode CSM Present: No
Active Blind Spot Sensitivity CSM Present: No
Active Blind Spot Strength CSM Present: No
Active Blind Spot Haptic CSM Present: No
Do I simply change all these to Yes? Or are there other steps required. Any guidance will be appreciated. Thanks!
