Adding 3rd Brake Light on Cab & Chassis
Wineaux
Cupertino, CA
I am having trouble with getting an aftermarket 3rd brake light to work on my Cab and Chassis truck. I checked the blank plate, and the plug still runs to it. I don't see why they would need to change the wiring from a regular 3500.
I thought that maybe it just needed a fuse. Nothing on the fuse chart says "3rd Brake Light," but there is a fuse labeled F36 - Electric Back Light (if equipped). It's a 30A FMM/MCASE. I checked the fuse box, and that one is installed.
Has anyone dealt with this before? Is there another fuse slot that might make it work?
I have the same issue on a 2018 cab and chassis i converted to a regular dually. Have you figured it out?
Is there a fuse spot for “CHMSL” that stands for center high mount stop lamp which is the 3rd brake light
Would be my guess is it needs to be turned on in the BCM configuration, as the output is from the BCM.
@Jimmy07 can probably help.
