Is this happening when the truck is cold / cool and is still warming up to operating temperature? Or does it happen irrespective of the engine coolant temperature?My 2024 Ram 3500 6.7 w/ Aisan is pulsing under light throttle , light load. Any body having this issue ? Only has 8700 miles. This started around 3000 miles. If I let off , or increase throttle pressure it goes away.
Temperature doesn’t seem to matter.Is this happening when the truck is cold / cool and is still warming up to operating temperature? Or does it happen irrespective of the engine coolant temperature?
Does the symptom show up when on cruise control? Could be the Throttle Position Sensor. Maybe try some electric tuner cleaner.If I let off , or increase throttle pressure it goes away.
I’ll give that a try.
I only have 9 K miles, why would it be dirty already ? Any ideas ?
Thanks for your help
Yes, stock air setup, original filter. I’m going to change all filters next week.It happens, doesn't take much. but just pull it off the tube, clean it really good and let it dry then throw it back in. mine did it and oddly enough google had the answer lol.
im assuming stock air setup? cause aftermarket oiled filters can do that as well.
Recently replaced the MAF. It seems to have helped. It still isn’t right.Always clean MAF and MAP sensor every service.
