ACEd
Looking at 3500 Megacab 4wd SRW 6.7 diesel ve 6.7 HO diesel specs. I see both the base 6.7 and the 6.7 HO GVWR is 12300 lb, but the Payload is 4300 for base vs 4140 for HO - I assume that is the additional weight of heavier transmission on the HO Then I look at GCWR (3.73 axle) and base is 28300 lb (tow rated 19830 lb) while the HO is GCWR (again 3.73) is 32710 (tow rated 24000 lb). I understand the higher GCWR is associated with the additional horsepower / torque, BUT IS THERE ANYTHING ELSE DIFFERENT ON THE HO - springs, BRAKES come to mind as the higher GCWR would presumably require better braking?
Thanks, Ed
Thanks, Ed
