6.4L Dual Batteries Without Isolator
DampLemonade
Single 220a alternator on a 6.4L here. I'm looking to get a dual battery setup in plain parallel for extra CCAs in the winter. I don't need nor want an isolator since the second battery is primarily for startup. The alternator itself certainly shouldnt care about the extra amp-hours to recharge both, but is there any trick to getting both batteries hooked up without making the truck angry? I plan on using some 0ga directly between the batteries' respective positive and negative terminals.
Only reason I'm asking is because my factory battery negative has that IBS crap (pun intended) on it. From what it sounds like in this thread (link), guys running high-amp loads simply bypass the sensor but only because it has a relatively low ampacity. To be clear, I'm not running a large winch or anything, I just read that thread for info on what the IBS actually reports. It would seem I do want the second battery wired in with the IBS so the voltage reported is that of both and not just one battery.
Is anyone here running a dual battery setup like I'm talking about? No relays or switches, just always connected in parallel? Is there a specific way to connect the two to make the truck's sensors happy? Or am I just overthinking it?
I am foggy on how the charging system responds to the IBS signal, but I would assume that it makes a judgement call on charging current vs voltage, allowing it to make a better assessment of battery health and charge accordingly. If you paralleled a second battery, it would just see it as one big healthy battery. I can't see how it matters either way.
Do the 6.4 trucks have extra space for an larger battery in the tray like the diesels? H8 (grp 49) > H7 (94R) > H6 (grp 48)
I did and it's been working perfect! The truck never gave any weird electrical issues or anything.
I ended up getting two new walmart Everstart AGM batteries, both H7, and installed them at the same time. I ended up repurposing the original truck battery to power my trailer winch, haha. Also used NHOverlands battery tray for the truck. Putting that together was fairly easy too.
Overall it's made a huge difference on my cold start performance for situations where I don't have somewhere to plug in the block heater
Pics of your setup would be appreciated.
Sorry its been a minute I've been busy and on the road a lot, but here ya go
how the second battery sits on the passenger side
plenty of room for the computer to be tucked away underneath
the aux bat positive lead attached directly to the lug on the main battery
the whole setup, in addition to my extra electrical add-ons.
I know my cable management could be better, don't flame me too hard :(. Soon I'll be adding a bigger bus bar in the space by the NHO battery tray to make things a little cleaner. In addition to the second battery, I also run a small winch in the bed to help pull things up ramps into the bed, I have a jump plug I made out of a large Anderson connector, and I have the power wire for my SwitchPros system, so it's admittedly starting to get a little crowded with wires on the main battery...
Thanks for sharing!
