Crusty old shellback
So I took a trip this weekend, 875 miles.
For the run home, I wound up doing a 450ish mile trip without fueling back up. A few things I noted.
15.1 MPG on the lie o meter
When the range miles display hits 50 miles left, the fuel pump light come on saying you need to refill.
When the range miles displays 10 miles left, it then turns to low instead of counting down to 0.
I still drove at least 10 more miles before I got to my gas station.
Filled up this morning with almost 28 gallons of gas. So if the tank is indeed a 32 gallon tank, then it has at least a 4 gallon reserve after it says you are out of gas.
On a side note, pump stopped at $150. and I had to start it back up to finish filling, $173 dollars total at $6.02 a gal.
