6.4 2015 Ram 2500 intermittent running problem
GoLikeHellMopar
I have a 2015 Ram 2500 crew cab laramie 4x4 that has been having intermittent running issues. Currently have 81,XXX miles on it and over the last two weeks it has randomly started to have choppy idle, while searching for rpms, and then stalls out. This has mostly happened when parked and only one time where I was driving down the road where it died and could not get it restarted. There were no codes when it stalled but the service electronic throttle control came on the dash once. I had it towed to the dealer after I went through trying to find connection or other issues I am familiar with. Once the dealer actually looked at it, sitting for 4 days, it fired right up but ran "a little" rough. Then it started running just fine. The only thing the dealership found was that it threw a code for bank 1 and 2 02 sensor out of range and it lost communication once to pcm. After them "looking" at it for 3 more days, they could not find any issues and it was running fine. They said they checked all the connections for main wiring harness and could not find anything. I drove it home with no issues and drove it several times over the next week. The weather was around 20 to 40 degrees with no precipitation while all this was going on.
Once home, I did several checks for grounds and wiring harness connections at the pcm, sensors, etc., with finding nothing loose or issues. I opened up the fuse panel and made sure everything was secure down for fuses and harness. I did checks of hoses, etc. for any kind of vacuum leaks, and found nothing. I tightened down the intake 8mm bolts, which I have done before, and nothing was overly loose. I decided to go ahead and change out the front 02 sensors myself ,based on mileage and low cost. It seemed to run just fine. I cleaned the throttle body as it had some build up and a little bit of oil. I threw in a standard paper air filter to rule out any kind of oil interference that some could say coming from the standard airbox K&N filter. The K&N has been in there since 3,000 miles and cleaned every 20K. I found no miss fires logged on the scan tool while watching live data and nothing stored.
After not driving it for two days, I went out to run an errand. It started fine but then went back into a choppy idle and then died out after about 20 seconds of searching for an rpm. It started right back up but then died. You could smell it running rich and I also smelled a hint of oil. I looked at connections for maf, map, iat, throttlebody, battery, etc. and found nothing. Throttle body checked clean, no oil on the back or build up hindering operation. I pulled the connection to the MAF and it popped the service throttle control error on the dash. I also pulled the MAP sensor and it lit the CEL for a MAP sensor out of range and it seemed to start to smooth out the idle. I jumped back in, shut it off and started it up again, and now running fine. I had left both the MAF and MAP unhooked when restarted so I plugged them back in and still runs fine. I cleared the codes I took it on a run and it is not in limp mode and idles fine. Battery is full charged, full of fuel, 35 degree weather no precipitation. I turned off the heat / defroster when it started to choppy and nothing changed. No missfires registered on scan tool.
Any ideas on what else I can look at or missing for this intermittent?
Truck has always ran smooth until at 72K, about 6 months ago, the MPG started to drop from just below 15mpg to 12.5 to 13 all the time. One day I left to go to work and it seemed like it was going in and out of limp mode after I got a mile away from my house. It was a standard warm summer day. It cleared it self up as I was turning around to head back home. I checked and there were no codes, no misfires, or nothing else as I backed into my garage. The service throttle control did not show up at that time. I shut it off and went under to see if I see anything or find anything else. I started it back up and it was the choppy idle and then stalled out. I could get it started but loopy idle and die out. I took a shot, based on something I experienced with another 1500 with the 5.7 hemi, and changed out the MAP sensor, MAF sensor, and PCV. As soon I did that, it started and ran fine. I decided to change out the plugs at that time too. It had been running fine until this happened at 80K
I appreciate any ideas.
Might check fuel pressure. I've had fuel pumps go out and it didn't set any codes before, so it would be worth a shot to check. The "going in and out of limp mode" feeling really sounds like low fuel pressure to me.
