50 Gallon
DirectJH
So can anyone with a 2024 Ram 3500 that had the 50 gallon tank from the factory tell me what the settings are for it? How many liters are listed? Low fuel %? And empty? Doesn't seem like it should be an issue the tank came from a 22 put it in my 23 set the numbers I wanted and no issues. With the 24 same settings give me a check engine. When I research the code it comes up with it didn't change in the expect time. Which in itself I would think is odd because what if you only put in a couple of gallons. No that is not my case my reserve is 50 gallons also. It also doesn't check engine if I get below a 1/4 tank.
I added my 50 aftermarket and never found any settings that worked so I put it back the the 30 gallon settings, which isn't what you asked just my experience
My tank listed at 189 liters in Kanukistan.
