Gettin There
Greetings, I purchased a 2019 3500 6.7 HO Diesel and pulling a 40' 5th wheel RV... is it ok to run 4WD High to help pull most of the time or is it better to use it when you have to?
Just to make sure that you understand... These are NOT all wheel drive.
You absolutely will destroy drive train components if you apply 4x4 on hard surfaces.
These are "part time" four wheel drive systems, this means not intended for use other than when traction is limited such as snow, mud, loose surfaces and such. Once on firm ground the system is to be turned off again as soon as possible.
A car or SUV (think as examples a Subaru or a Lincoln sedan with AWD) is a "full time" system. These have very specific engineered systems that allow for continual use of all wheel drive on every surface from snow and ice to interstate travel on 90° days.
Should you challenge your truck to act as a full time system or as an all wheel drive system.... you will notice sever binding of the drive line as you attempt to turn, you will notice hopping and lurching as pressure builds and releases from a wheel as the tire is forced to slip/spin, and soon you hear a loud metallic bang sound as one of the driveshafts or the transfer case is destroyed.
The next sound that observe will be the sucking sound applied to your bank account as your money is pulled out and used to fund the non warranty repairs of your drive system.
What is extreme?A little extreme no?
I know I'm gonna get hell for this, but it seems to me that a person pulling 20,000 + lbs around the general public with that kind of lack of any common knowledge about how their trucks drivetrain
works concerns me greatly! Sir, please read your owners manual cover to cover, it explains some of what you need to know about towing and when to use 4x4 high and lo. Maybe search for videos
on the subject.
