P2201 nox sensor , or exhaust system needs maintenance, so then I had to take it in and they’d manually regenerate it. I’ve replaced 3 different sensors and they never fix it so that it would regen on its own. Now at least the Cummins lawsuit has given me 4 more years warranty for the ecr system.What specific DTC’s is your truck throwing?
I heard it a few times and it would go on the dash saying it’s doing it just for about 6 mths after I bought it new. After that every year , the exhaust system needs maintenance warning came on and they would manually regen at the dealer.How do you know it hardly ever regens?
NOx sensor deals with SCR not the DPF and regen.
Yes, I took it into the dealer every year roughly when the warning light came on saying exhaust needs maintenance. The nox sensors have been going off in the last 4 years. Just wondering , will an additive hurt anything to try and clean the dpf etc?So that’s the upstream nox sensor, has it been replaced? What’s the service history been to repair the problems?
If he has a cel on for a exhaust component will it still regen?The dash only shows the regen message if there is an issue. Normal regens are not visible on the dash of your 2014, so no regen codes and no dash warnings is a good thing and indicates normal operation of the DPF.
It sounds like your dealer is mixing exhaust components up. The NOx codes have nothing to do with needing a manual regen.
Archoil 6400D is what I would recommend if you want to run a DPF cleaner.
