Hey I'm new here. I'm looking to upgrade my truck and will be hauling a double deck 40 ft livestock trailer most of the time. Is the 5500 worth it or should I go with the 4500, thanks.
I don't know the max pin weight but I do know it'll be maxed out occasionally... as for gears I was considering 4.44 but I'm not sure as half the time I'm going thru central Illinois and the other half thru southern Ohio and west Virginia and I've never driven with anything higher than 4.10What’s the max pin weight?
What gears are you considering?
A 3500 C&C with 4.10’s has a higher GCWR than a 4500 C&C with 4.10’s, but a lower payload.
A 4500 C&C with 4.44’s has a higher GCWR than a 5500 C&C with 4.44’s, but a lower payload.
Peak towing for the C&C trucks is the 5500 with 4.89’s.
