4 way light connection on 2022 Limited
chc01a
I just took delivery of a 2022 Ram 3500 Limited Mega Cab. I cannot find the 4-way light receptical. The build sheet and window sticker both clearly state 7 way and 4 way trailer connection. I checked with the dealer and looked at 3 other 2022 Limited trucks and there is no 4 way trailer light connection. Does anybody know why this connector is missing or where it might have been hidden?
Thats in the standard equipment list which optional equipment will take away from that but the standard list will still have it (clearly labeled as such on the window sticker)
If you have the 12 pin for a trailer camera you dont get a 4pin i had converted all my trailers to 7 pin years ago as even my 01 and 05 only had a 7 pin… you can buy a 4-7 pin adapter 5$ and keep it in the truck too
I haven't seen a 4 pin on a HD truck in forever (if ever). Easy enough to buy an adaptor cable though.
My '21 PW has a 4 pin.
My '04 doesent.
But like stated, you can get a 4 to 7 adapter. I have a few of them. Work just fine.
2022 3500 Laramie Crew Cab Long Bed did not come with a 4 pin connector. Will have to purchase the 7 to 4 adapter. Build sheet is misleading.
Same here no adapter. Will probably carry one just in case but all trailers I hook to should be of size to need 7 pin
