4.5G aftermarket front locker or LSD status?
patricio2626
Has anyone heard anything about a locker or LSD for front axle yet for '19-'20 HD's?
ARB makes one for the front. Still waiting on them to make something for the AAM 12 rear axle.
ARB RD 197 is the locker for the front axle. It's an AAM 9.25. They dont make a rear locker for the AAM 12 found in the HO 3500s.
I called ARB tech support and they told me that ARB RD 197 does not fit newer models.
Do all 2021 3500s have the AAM 12, or is it only certain 3500s?
So any 3500s, even if a dually, if it's not HO it'll have the AAM 11.5? If so, does the AAM 11.5 ARB air locker work, the ARB RD 139? I'm wondering because an ARB dealer in my area said it's only for models 2018 and older, that newer models are not compatible with the ARB RD 139 (rear) or the ARB RD 197 (front).
For what it's worth, the latest Dodge/RAM application guide from ARB lists both front AAM 9.25 and rear AAM 11.5 axles as "2003 on", fitting the RD 197 and RD 139 lockers. There's footnotes indicating the front RD 197 for 2007-on requires a ring gear spacer and longer bolts, while the rear RD 139 won't fit some 2016-on dually's that used a 16 bolt ring gear.
FYI, The 2019 and up 3500 with HO, does has a set of different AXLES, AAM 10.5'' FRONT & AAM 12'' REAR.
I got the same word from ARB, 2019-newer has a different front axle or spline count from the 2018-older and the Power Wagon (33 count). Haven't found a Mfgr that claims to have a locker to fit.
