4.10: rpm @65mph
raven_dt
Can you 6.4/4.10 owners give me what your rpm is at 65mph. We typically tow at 65mph max so trying to get an idea of where we would be at in the powerband and mpg towing our 7k TT.
Up a sustained 6% grade with 37s and right at payload capacity (hauling, not towing) mine was cruising right at 2500RPMs a couple months ago.
Can't say I've paid close enough attention on flat ground though as I don't drive 65 very often.
This is easy to calculate. Math it.
keep in mind you need to know the exact tire size and your speedo needs to be calibrated for your truck to match the math.
hint: it’s 10% more than a truck with 3.73s
Something not right. My new 21' has 3.73 and it sits at 1750 at 70 MPH. Now the window sticker says 3.73, wonder why we are the same?
Thx, I went ahead and created my own in excel.
New 2500 6.4 eta is 6/16 to 6/30...still wondering about the 6.4/4.10 mpg. For reference my 7.3/3.55 (87 octane/unloaded). Lie-o-meter is typically .5mpg optimistic:
Are you replacing your Ford with 7.3 gasser? If so why? My 2020 Power wagon with 4.10 and 35's will get that kind of mpg if driven 65-70mph. This was with stock tires and my lie meter is about the same as yours sometimes it is almost spot on other times up to 1 mpg off.
Thats my 2020 7.3. 15-16mpg from a big block is pretty good. The 7.3 is great, the 10 speed not so much. About 90% in daily driving its fine. Otherwise, slow shifts, erratic downshift, etc. The 7.3 is good enough to make me tolerate the 10 speed...maybe. When I get the call that the Tradesman is at the dealer it might be a difficult decision to part ways with the Ford. And I'm a Ram guy...
**edit**
I'm worried that I'll get similar or less mpg with a smaller/less powerful engine. That's why I ordered the Ram w a 4.10 to bridge the power gap. However, with the 4.10, am I losing the mpg that I need for range? The smaller fuel tank in the Ram makes the mpg a concern on longer tows. We camp 3-4 times a year at a campground about 245 miles away (500 round trip). The 7.3 has the range to get there without stopping (barely). It looks like the 2500 would need a fuel stop before reaching our destination.
**edit**
4.10's won't make a difference on your mpg in fact you might get better. My good buddy had a 2019 RAM with 3.73 and he traded for a 2020 with 4.10 and his mpg actually was better. The small tank does suck no doubt. I wish it were at least 36 or bigger
I usually lock 10th out when towing because it causes excessive downshifts. 100% agree, at least you can order a 1500 with a 33 gal tank, why not give the 2500 buyers a 34 gal standard. The 6.7 aren't that much impacted by the 31 gal tank. But with gas engines range is important for those of us that tow relatively long distances. 2500 mile trip coming up in July.
That 7.3 Godzilla is a nice piece. Ford nailed it with that motor.
Also there’s a TSB out on the super duty 10 speed transmissions .... check into that.
