3d Printed Bed Grommet
CortexM0
I needed to temporarily run some wires into the bed of my truck. I wanted a fairly clean install, but didn't want to permanently modify anything since I was going to have to remove it in a few months. I ended up 3d printing a grommet to replace one of the existing plugs in the front of the bed.
Just pop the existing plug out, and snap this one in its place. The hole is sized for 3/8" loom from H.F. Tools. The slit allows you to twist the plug open (prior to installation) and slide existing wires into place.
Files can be found here: https://www.printables.com/model/701061-2023-ram-2500-bed-grommet
Would you mind sharing the cad file? Using the free fusion360 and converting stl/mesh sucks with it.
Nice work guy
Firstly, thank you both for providing files for this stuff for free.
Secondly, @Brutal_HO , I'd love to hear about how you made that angled plate for the rubigrid. Feel free to respond here or DM if you prefer. I am curious how one goes about finding the correct angles and curves for something like that. I've got a project I'm wanting to start for a mount for a voswitch panel, but I've got no clue how to do the radius corners outside trial and error.
I made a "CAD" pattern best I could and went from there. Several sessions still learning Fusion360 and several prototypes later...
Most probably know, but in this context, CAD = Cardboard Aided Design. LOL
RE: Fusion360. Starting with a sketch with constraints and dimensions, one can make nearly untold number of alterations to the model just by changing the sketch. Changes to the body/component also flow back to the sketch.
