37x12.5 17R on AEV wheel
diablo82
Does anyone have experience running with this set up? I believe both AEV wheel offset are +27mm. Would the Carli leveling kit make any difference in term of rubbing issue? Or should I stay with 35s?
Thanks
It has been done, it will likely rub, especially with articulation, level does not make a difference for clearance with the radius arm, and you’ll have to beat the pinch weld down or at least trim your wheel well liner. I’d stick with a 35.
Thanks for the advice.
