35s with Ram 2500 air suspension
spinned
Is there anything special you folks are doing to put 35s on the 2500 with factory air suspension? I don’t need a big lift but enough to make 35s look right. Will the rear just self level anything I do to the front? thx
air only keeps the bed from sagging. doesn't know anything about the front or the level between front and back. 1" spacer or lift coil should clear 35s in the front with no/minimal trim depending on your wheel choice.
I’ve been looking too. You probably won’t need to adjust the back if you are just doing a 1” lift in the front. I’ve seen you can buy a air level sensor rod that is 1” longer than the stock one to trick the system and level it 1” higher in the back. I think it is part of the 2.5” Carli package
