2nd Gen to 5th Gen 2500
Hi All,
There is a wiring harness on the passenger side rear of my truck that has 3 capped wires. The one is the break light wire to wire a third brake light on a cap which is what I have done. RAM Engineering youtube page says the other wires are battery and acc power only if you have auxiliary switch package (which I do). I hooked up to test and I didnt get any power with the truck off or with it on accessory. Anyone use these? I want to run a 12 volt to my bed using these to avoid running a whole wire all the way from the front. Anybody familiar with these? I may have had a bad ground but I had a alligator clip straight on the frame, so may try that first but decided to post in the meantime.
Thanks,
Thanks,
