Yep, took it to RAM today and they’re saying that the RF module has an issue so now I have an appt for the 29th. Hoping it’s a quick fixI'm assuming you put the sensors from the 25 in the wheels? I had no issues changing TPMS. Do note that 24' and earlier sensors do not work.
Ya I had same issue after taking delivery. Stock wheel. Rf module had to be replaced. My keyless door lock didn’t work either. All good since.Yep, took it to RAM today and they’re saying that the RF module has an issue so now I have an appt for the 29th. Hoping it’s a quick fix
Ok, changed my wheels and tires, moved the TPMS from the stock wheels to the new once’s. 24hrs later, two of them disappeared. Any ideas?
View attachment 85898View attachment 85899
Read the thread, RF Module80 psi front and rear? Or are the sensors displaying the wrong tire front left?
lol, read the question… 80 psi front and rear?Read the thread, RF Module
Sorry for the late response. I inflated the tires to 85 just to see if the tpms would notice and reset. Pulled all four back down to 60 now and waiting for my appointment. My concern now is how long they’ll take.lol, read the question… 80 psi front and rear?
The RF module may explain the missing RF and LR tires, I’m asking about the overinflated tire(s).
Clearly you need to heed your own advice a read the thread better. Your first post asked a question answered by the OP with his first sentence, and your second post wasn’t any better.
And yes, once the system is working I’ll drop them as low as the tpms will allow. Probably 55Sorry for the late response. I inflated the tires to 85 just to see if the tpms would notice and reset. Pulled all four back down to 60 now and waiting for my appointment. My concern now is how long they’ll take.
That sucks….. I’ll keep updating this thread as the issue progresses.Good luck with the tire air pressure. I have had it work perfect for months . Then all of a sudden low tire alert, air pressure reading not available. Have taken to Dealer multiple times they can not find anything wrong. Then works again for months then start all over again. Again dealer finds nothing wrong. I am afraid one of these times I will have a low tire and think its nothing, keep driving and wreck a tire or pull over to check and another driver hits you from behind and the tire is fine. Other people are having this same problem. Something Ram has to figure out.
