24 Limited Heated Seats into 21 Tradesman Swap
STAR H RANCH
Hello Again Everyone,
I'm looking at a great set of Heated / Cooled front seats and a rear heated seat from a 24 2500 Limited to swap into my 21 2500 Tradesman, good looking set donor truck only had 6k on it, anyways I've been doing some reading and what I'm finding out is that I believe the passenger seat is plug and play and so is the rear seat, but I've heard that the drivers seat is not, I read that RAM put different plugs in 23-24, and that 22 and below are different, so in order to make this swap I would need to put some new harness's on the drivers seat along with some other things to make it work? Anyone have any experience on this, any and everything you guys are willing to share would be appreciated, part numbers pictures, video's etc., thank you all for your help. I was hoping that @Jimmy07 would have some input. Thanks.
You ever tackle this? I would just look at or take pics of each seat's connector and compare, then compare what wires are actually populated on the seat side of the connectors as well. The harnesses for the fully loaded seats are fairly cheap so may be worth
