Good morning everyone.
Did some searching but not finding specifics so…I
Noticed last week the front tires on my 2022 3500 DRW are beginning to feather ? / cup ? on the outside edges on both driver and passenger side. I’m running 80psi cold on factory Nexen’s. Currently 6,500 miles on the truck. Mix of towing and empty driving. Mostly highway miles. I’ve been reading up on this and from the searching / reading I’m thinking this is an alignment issue. I called the dealer where I purchased the truck and they can’t do alignments on crew cab DRW trucks. So that leaves me to find a shop in my area that can. (I think I found one)
My questions are:
#1. Are the Thuren specs applicable to a 3500 DRW truck with stock suspension and tires.
#2. Do you feel these specs will help with the wear issue I mentioned?
#3. What are your thoughts on requesting replacement front tires under warranty? Seems to me if the truck is improperly aligned or aligned in such a manner as to cause accelerated and premature tire wear, the damaged tires should be replaced under warranty. Thoughts? The owners manual suggests DRW trucks be rotated at 7,500 miles so I’m easily 1,000 miles shy of their recommendation.
Thanks in advance, as always your opinions and shared information are greatly appreciated.
My questions are:
