KaoticDually
What’s going on Ram Community,
I’m kind of new here this is my first actual post. I’ve been reading and skimming through different threads trying to learn more about these trucks since this is actually my first diesel truck.
I’ve got a 2022 Tradesman with the 68RFE. On July 17th I took the truck out to Texas for a little “weight loss.” The guy who did it told me I should drive it around afterwards so the transmission could relearn. I drove the truck about 15 miles, then hooked my trailer up and drove back to Florida.
Before the weight loss I’ve never had any transmission issues & has always shifted smooth. I’m not the type to put the pedal to the metal either, I gradually accelerate, especially when hauling. Since the weight loss, I’ve put roughly 2,000 miles on the truck.
Since then, I’ve had two issues pop up:
• July 29th: P0755 – Shift Solenoid B (transmission related)
• August 7th: P226C – Turbocharger Boost Control A Slow Response
Along with the codes, I’ve noticed the truck shifts smooth from 1st to 2nd, 2nd to 3rd, then when it goes from 3rd to 4th there’s a small kick, and after that it’s smooth again (4th to 5th and 5th to 6th are normal).
Has anyone else experienced this after a weight loss? Could it be the transmission relearn wasn’t completed properly before I started towing heavy again? And what’s the best way to address the solenoid and turbo actuator issues?
For those who’ve been through this, did you have to do a full transmission relearn/reset, or did it come down to replacing parts? Any tips or first-hand experience would really help.
If this has already been covered before, I’d appreciate if the admins could point me in the right direction so we don’t have to start over or repeat a thread that’s already out there. I just want to make sure I’m looking in the right place.
