snlsmith
A couple weeks ago I tried to use the remote to start my truck and I just heard a click. Tried to start with the pushbutton and same thing. Threw it on the tender overnight and started fine so figured it was just low. Three days later same thing and measured the battery at 10.6v. Back on the tender, same thing, started fine the next day. Fast forward a week and when I opened the door the auto-extending running board didn't pop out. This time measure at 7.8v (may have just jacked the battery this time). After being on the tender for a few hours, opened the door and the step came out. Closed the door and stayed to watch the lights. Every light (overhead, back seat cargo LEDs in the seats, bed) as well as the dash turned off, so no lights staying on that I could see. I also have nothing plugged into the front/rear/armrest USB ports, AC outlet, or DC outlet on the dash above the radio.
Battery tender was green this morning showing a full charge, so going to disconnect the negative cable and hook up a multimeter to start testing, but would be nice if I had something specific to check first.
Possibly a coincidence, but last night I remembered that during our last trip a month ago, the USB outlets by the rear seat AC vents did not work. The cable itself was good as we just moved it to a USB port on the dash and the phone started charging. If you know exactly what fuse that is it would be appreciated as the fuse descriptions are not very clear.
