2025 Ram 3500 Front Camera Relocation
jbonnot03
Gulf Coast, Tx
Upon researching this, I didn't find any info other than AEV's bracket that will only work with their bumper and their instruction sheet. Off into the weeds I went. Using AEV's info sheet as a guide.
First remove the push clips and remove the radiator cover.
Automotive Exterior Windscreen wiper Glass Windshield Hood
Note: There are 2 clips on the backside of the radiator cover
Engine Automotive Fuel System Fuel line Automotive Air Manifold Hood
Automotive Exhaust
Next using a 10mm socket remove the bolts holding the upper trim piece on. There are also 2 push clips(one on each end)
Engine Hood
I didn't get any pictures of these next steps as most of it was done in the driveway at night.
Remove the 10mm bolts holding in the grill shutters.
Engine Rust Synthetic rubber Hood Windscreen wiper
And remove the 8mm bolts holding the grill to the grill shutters. There are 3 of these that I removed. One on each side and one in the middle. These were accessed from the back and difficult. I used a sidewinder ratchet from Amazon to get these 3 out.
Automotive Exterior Hood Grille Bumper Headlamp
There are also some clips that hold the grill to the shutters. You can sort of see them above and to the left of my hand in that picture. Pry down on those and they will pop out. This gave me just enough room to get my arm down to the camera. There are 2 3mm allen head screws holding the camera to the grill. I removed those along with the Christmas tree fasteners that hold the wire to the grill. I disconnected the camera at the connection shown below (Center of picture...gray with orange). There is a red clip that slides towards the driver's side and push down on black clip.
Silver Engine
Now for the reinstall...
I scrounged up a couple of brackets I had laying around. One was a T bracket (found at Lowe's or Home Depot) and the other seems to be a bracket for a rubber hood latch (I think). I cut the bottom of the T off and the bottom of the latch bracket. Had some nuts and bolts on hand.
Bolted the two brackets together.
Used a plastic junction box from Amazon and did some Jig sawing. Mainly for more camera protection.
Somewhat finished product. The wire is temporarily routed and the camera works. I have a longer extension cable ordered to route it more permanently.
