2025 Limited Longhorn Aux question.
Xflight29
My 2020 I needed to jump two ports to have pass-through power to cab. Question, seeing that there are only 4 ports compared to the previous 6 on my 2020 do I need to still jump 2 ports to have in cab power? I was hoping they symbolized all this with the 2025 model year.
The aux switch wiring diagrams haven’t hit the body builders website yet.
Any wiring diagrams in the package with the wiring?
Same as the previous years. with only 4 switches I was hoping they might have made it simpler to have Aux cab power.
Odds are the wiring is pretty much the same. If you open up the PDC what do you have in there?
If it’s the same then you should only need to connect the one internal connector (the grey one I believe) to have ignition power inside, you just have to cut/tap the wire that currently loops back to that connector and then heads to the rear.
