2025 battery connection points/questions
Ballbearing
Hello, I have several questions involving battery connection points and functions. I have searched repeatedly, both here and the internet to no avail. Sorry if this has been covered and direction to a specific thread would be greatly appreciated if it has. Everything I've located has been for prior generations of trucks.
With that said, I am attempting to hook an accessory circuit (without using the in cab switches) direct to the battery. I would also like to add a winch at some point down the line so I'd like to future proof that connection. On that note I haven't found a good location for the winch cabling on these newer trucks.
In looking at the driver's side battery and fuse box there are several connections that I'm unable to find their function, or see if they are safe to use. Specifically, on the battery I see multiple positive leads connected to the box on top. Pic added for reference
Another option is the positive lead entering the fuse block which is just South of the picture I sent.
Thank you in advance ,
Jason
Just pick one of those blanks on the battery and install a circuit breaker. I have my circuit breaker attached to the side of the cover you removed to expose the battery.
Thank you.
AH64ID, when you say you see it: Is it a specific post in my pic? I assume it’s the post nearest the actual battery connection post.
On edit: I’m adding a 40A Maxi fuse in waterproof housing rather than a circuit breaker, but can/will change based on recommendations
Thank you.
Second post from the bottom, it has a small HAPP stamped next to it.
Are the studs now fused on the 25+ trucks?
HAPP no, everything else yes. I've seen post 4 (fused at 300 amps) referred to somewhere in RAM literature as the preferred location for high-draw aftermarket stuff. Also said the engine block is the preferred 0v location for such installations.
