2024 Big Horn AlfaOBD Light Settings
MADDOG95
Arizona
I have updated my OEM halogen headlights & turn signals with some Morimoto XB headlights and some 7440/7443: XB LED Bulbs.
I have an interesting hyperflash issue. When I use the turn signals one or both bulbs on one side or the other will work. It's very odd that at times only one bulb works and another time both bulbs work. The turn signal lights in the outside mirror case will hyperflash but not the turn signal bulbs under the headlights.
There is no access through my UConnect to do change any settings for the turn signals. Am I right in assuming that there is a setting I can access via AlfaOBD to set the turn signals to LED? Or is there something else at play here?
Also, regardless of the headlight switch position, my low beams are always on when ACC or RUN power is on. I'd like to run the low beams when the switch is in the headlight On or Auto positions and I'd like to run the two LED bars when the headlights are on and as DRLs.
The installation was pretty straight forward and everything was triple checked during installation.
Thanks in advance for any input you may have on the issues.
